Guys and Gals,
Here in Los Angeles there is a product called "Plast-Aid". For all of us that do repairs after locating leaks on plastic pipes, this is a life
saver. Those jet leaks that are too close to the bond beam to cut out the venturi tee,plast aid. That leak next to the equipment pad where there is a
bundle of 6,7,8 pipes and your leak is on the bottom, plast aid. I've applied this to pvc main line water service pipes running at over 100 psi and
have great success. In a pinch I highly recommend it.
Its in the store on this site.
Good stuff
I have used it even underwater to make repairs to fiberglass / plastic steps
