We use the earlier one without a tank, wouldn't be without it. If you need to sick a liner patch in the deep end it makes it simple.
Thanks! Do you use the tankless one to pressurize lines as well?
| Quote: |
Yes we do, you need to keep it as far away as possible and not on a solid deck else you hear the vibration. We also use a radio controlled socket to plug it in to so that its easy to turn off and on when listening without walking back and foreward.
I just got my pd-50 a few weeks back and have used it to pressure test, only on residential pools though. I make sure to keep it as far away as I can,
but have been successful with it.
I use a higher capacity air tank for commercial testing.
love mine, it is light weight and handy; sure beats hauling steel dive tanks around. I use it for diving and pressure checking. Only problem I have had is that the plastic in line filter connection leaks, it should be made of SS or Brass.
