Hi,
Ive only used Nitrogen tanks to pressurize the line, what are you all using.
I've always used air generated from an air compressor or in some cases a scuba tank
Does anyone have any recommendations as far as the type of air compressor that would be suitable?
Id like to try it, but I think it(the compressor) would be very loud, right?
Any info would be greatly appreciated!
Use a compressor with a tank, once tank is full shut off compressor and you will have silence as long as tank lasts
Its mounted in the truck and I have a 250 hose supply reel. With this setup the noise is generally far enough away not to bother me while listening for leaks. I do also have a smaller 4 gallon compressor on board in case the pool is too far away from where I can locate the truck. But you will find that the small compressors will run an awful lot when trying to locate some hard to pinpoint leaks, especially when they are down over 3 feet.
can some one edvice me how to use the XLT 17 to locate the leaks all I hear is a lot of static
We use co2. You get more volume than nitro because it is liquid. About $24.
Tank tends to freeze up on bigger leaks.
